Fattie with 6" pullback risers
  • Henry
    Henry
    Hi Guys
    I put a set of 6" pull back risers on my fattie on the weekend, previously I had the western bars with 4" straight and 4" pullback risers but my lower back ached after about 200klms, hopefully these will fix the problem as the seating position feels more comfortable now without stretching forward as much.
    If they work out I'lll have both the 4" sets for sale.
  • roadrunner14
    roadrunner14
    Looks good mate, hope it fixes the aches on long distances for you. Amazing the difference risers make to comfort once you get them right
  • lezchez
    lezchez
     Did you have to replace cables for the 6 inch risers
    Cheers Les
  • lezchez
    lezchez
     Cheers guys I think I'll get a set of 6 inches
    Les
  • jungle
    jungle
     hey henry are they buffalo risers
    Lookin' good, Henry. Please let me know when you're ready to sell your 4 inch risers....
    Henry, not sure yet - have you got pics of both fitted to the bike?
  • 308bever
    308bever
    looks good henry, let us know if it helps the back ache! (((-:
  • pafc64
    pafc64
    I put the 4" pullback risers on my 2011 Fat Boy lo as the standard bars are crappy & My hands got pins & Needles after 1/2hr of riding,anyhow the 4'' deffinitely made a difference but I still needed more so I tried the 6" pullbacks & all of the cables were long enough apart from the brakeline which was a bit tight & decided to snap at the bottom bango.
    Seeing as HH in adelaide couldnt get me a longer brakeline due to not being able to get the lower part for the ABS Im now getting my broken line fixed & lengthed 6" (I hope I still havnt heard back from them yet) & then will have to ride the bike 400km just to get the fuckin ABS reset.
    Hopefully the 6" will do or next step will be street slammers.
  • lewy
    lewy
    Hi Henry,
    Let me know if you decide to sell the pullbacks.
    Thanks
    Lewy
  • lewy
    lewy
    Hi Henry,
    PM sent
  • Hoges1974
    Hoges1974
    Hi guys
    Sorry to dig up and old thread but can someone confirm if you can put the 4 or 6 inch Harley pull back risers on a 2013 fatboy without changing the cables.
  • xlr8it
    xlr8it
    Yes , done 6" on mine with no problems
  • monkey
    monkey
    Nice
  • Hoges1974
    Hoges1974
     Thanks
    put 4 inch pull backs on yesterday no dramas really just going to put the throttle cables on the other side of the brake line.
    The bars are in a much better position now especially for hwy cruising
