Throttle position 09 FLHTCU
  • conmore
    conmore
    Hi there
    The proble I am about describe is really annoying me. All the Harleys I've owned have all had throttle cables as opposed to this bike (09 Ultra Classic Electra Glide) and the response from the the throttle (with cables) has been instant and smooth.
    This is the first bike Ive owned with throttle-by- wire and it works just fine off idle, but the main problem is at very low revs, particularly in 1st or 2nd gear, when I roll the throttle on from completely closed there is about 3-4mm og roll before the throttle "engages" if that makes sense.
    It's my first fly by wire throttle so I'm not sure if it's me or I have a problem, but I'd greatly appreciate anyone who has experienced the same thing and addressed the problem with tuning or an adjustment of the serrated pot in the end of the handlebar or what?
    Cheers :)
