Online: Stuart, BigKangaroo
flasher unit in 94 sporty
  • timsporster
    timsporster
    hey all, the indicators in my sporty dont flash and im trying to locate a flasher unit for it
    thought it may have a relay like a car but turns out its a module
    is this correct? and what does it look like?
    cheers !!!!
  • pan head
    pan head
    Its under your seat.  I know on the 92 model behind the battery on the LH side of your bike, remove the module cover with the 3 screws.  There is a module there, but its the one behind that (with the wires going in and out of it) and I believe you have to remove the outer one to get to it.   Good luck hope this helps
     i had too just buy 1 this week for a job had a hard time trying  too find 1  all shops out of stock  found 1 in harley city melb only , i can give you  a P/N if you like
    174 bucks
  • kingchops
    kingchops
    If it's the three pronged cube type, you can get them on ebay U.S for around $25.  The same unit works on many cars, you could probably use one of those I'd suspect.
    your's is the self canceling style that works of the speedo yes ? if it is  what they cost original
