Ultra C cruise control problem
  • Two tone
    Two tone
    Has enyone had problems with the 09 FLHTCU cruise control. The switch on the dash lights up but its not engaging by the switch on the bars. Ive had the front off and checked the conectors ,are there any other obvious bits to check.
  • Rick1310
    Rick1310
    I known on my 07 which is cable, the return cable was not set correctly which cause it not to set. But yours is cable free so it may be the same sort of thing but eletric.
  • HogBag
    HogBag
    There would be a diagnostic code logged because the cruise stopped working you need to pull that code to help find the problem. The main plug on the ECM comes lose on those 09 baggers so I would check that its pushed home. The TBW plugs on the throttle body can corrode and need electrical grease to keep them dry.
  • HogBag
    HogBag
    Harley Trouble codes
    The following procedure will instruct in retrieving and clearing ECM Diagnostic Trouble Codes and TSM/TSSM codes thru the Harley guage cluster as well as a list of codes.
    1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
    2- Push odometer reset button in & hold.
    3- Turn ignition switch to Ignition and release the odometer reset button. Background lighting sould illuminate, sppedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
    4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
    5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
    P = ECM/ICM (Electronic Control Module) [EFI] / Ignition Control Module [Carbureted])
    S = TSM/TSSM (Turn Signal/ Security Module)
    SP = speedometer
    T = tachometer
    6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
    7 - Record the codes.
    8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
    NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
    9 – Press and release the odometer reset button to continue to the next module.
    10 – Turn Ignition switch to OFF.
    On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
    "No Rsp" (no response) will also appear if the run/off switch is in the off position when doing this procedure.
    HFSM = Hands Free Security Module
    TSM = Turn signal module
    Priority/DTC/Fault condition
    1. P0605 ECM FLASH Memory Error
    2. P0603 ECM EEPROM Memory Error
    3. U1300 ECM Serial Data Low
    4. U1301 ECM Serial Data High
    5. U1097 Loss of Speedometer Serial Data to ECM
    6. U1064 Loss of TSM/FSFM Serial Data to ECM
    7. P1003 System relay contacts open
    8. P1002 System Relay Coil High/Shorted
    9. P1001 System Relay Coil Open/Low
    10. P1004 System Relay Contacts Closed
    11. P1009 Incorrect Password
    12. P1010 Missing Password
    13. P06415 V+Vref 1 Out Of Range
    14. P06515 V+Vref 2 Out Of Range
    15. P0373 CKP Sensor Intermittent
    16. P0107 Map Sensor Open/Low
    17. P0108 Map Sensor High
    18. P0374 CKP Sensor Synch Error
    19. P1511 Throttle actuator control power management failure of throttle control actuator
    20. P1600 EFI Module Processor Internal Error
    21. P1270 TGS Validation Error
    22. P2107 EFI Module Processor Internal Fault
    23. P2101 throttle actuator control motor circuit range/performace error
    24. P2122 TGS1 Low/Open
    25. P2123 TGS1 High
    26. P2127 TGS2 Low/Open
    27. P2128 TGS2 High
    28. P2138 TGS Correlation Error (Twist grip sensor)
    29. P0120 TPS1 Range Error
    30. P0220 TPS2 Range Error
    31. P0122 TPS1 Low
    32. P0123 TPS2 High/Open
    33. P0222 TPS2 Low
    34. P0223 TPS2 High/Open
    35. P2135 TPS Correlation Error
    36. P2119 EFI Motor Throttle Body Range Performance
    37. P2100 EFI Motor Circuit Open
    38. P2101 EFI Motor Circuit Range Performance (Actuation Error)
    39. P2102 EFI Motor Circuit Low
    40. P2103 EFI Motor Circuit High
    41. P2176 EFI Closed Position Not Learned
    42. P1514 Air Flow Fault
    43. P2105 EFI Forced engine shutdown
    44. P1501 Jiffy Stand Sensor Low
    45. P1502 Jiffy Stand Sensor High
    46. P0572 Brake Switch Low
    47. P0117 ET Sensor Low
    48. P0118 ET Sensor High
    49. P0112I AT Voltage Low
    50. P0113I AT Voltage Open/High
    51. P1351 Front Ignition Coil Driver Open/Low
    52. P1354 Rear Ignition Coil Driver Open/Low
    53. P1352 Front Ignition Coil Driver High/Shorted
    54. P1355 Rear Ignition Coil Driver High/Shorted
    55. P1357 Front Cylinder Combustion Intermittent
    56. P1358 Rear Cylinder Combustion Intermittent
    57. P0261 Front Injector Open/Low
    58. P0263 Rear Injector Open/Low
    59. P0262 Front Injector High
    60. P0264 Rear Injector High
    61. P0562 Battery Voltage Low
    62. P0563 Battery Voltage High
    63. P0501 VSS Sensor Low
    64. P0502 VSS Sensor High/Open..
    65. P1356 Rear Cylinder No Combustion
    66. P1353 Front Cylnder No Combustion
    67. P0444 Purge Solenoid Open/Low
    68. P0445 Purge Solenoid High
    69. P1475 Exhaust Actuation Position Error
    70. P1477 Exhaust Actuator Open/Low
    71. P1478 Exhaust Actuator Shorted/High
    72. P0131 Front Oxygen Sensor Low
    73. P0151 Rear Oxygen Sensor Low
    74. P0132 Front Oxygen Sensor High
    75. P0152 Rear Oxygen Sensor High
    76. P0134 Front Oxygen Sensor Inactive
    77. P0154 Rear Oxygen Sensor Inactive.
    78. P1510 EFI Limited Performance Mode
    79. P1511 EFI Power Management Mode
    80. P1512 EFI Forced Idle Mode
    81. P0577 Cruise Control Input High
    1. U1300 Serial Data Low
    2. U1301 Serial Data High
    3. U1016 Loss of ECM Serial Data
    4. U1255 Serial Data Error
    5. B1142 Smart Security System Internal Fault
    6. B1135 Accelerometer Failed
    7. B1136(HFSM) Accelerometer Tip Test Error
    8. B1151 Bank Angle Sensor(BAS) Short to Ground
    9. B1152 Bank Angle Sensor(BAS) Short to Battery
    10. B1153 Bank Angle Sensor(BAS) High
    11. B1154 Clutch Switch Input Short to Ground
    12. B1155 Neutral Switch Input Short to Battery
    13. B1134 Starter Output High
    14. B1121(TSM) Left Turn Output Fault
    B1121(HFSM) Left Turn Output Open
    15. B1122(TSM) Right Turn Output Fault
    B1122(HFSM) Right Turn Output Open
    16. B1123(HFSM) Left Turn Output Short to Ground
    17. B1124(HFSM) Right Turn Output Short to Ground
    18. B1125(HFSM) Left Turn Output Short to Battery
    19. B1126(HFSM) Right Turn Output Short to Battery
    20. B1143(HFSM) Security Antenna Short to Ground
    21. B1144(HFSM) Security Antenna Short to Battery
    22. B1145(HFSM) Security Antenna Open
    23. B0563 Battery Voltage High.
    24. B1131(HFSM) Alarm Output Low
    25. B1132(HFSM) Alarm Output High
    26. B1141(TSM) Ignition Switch Low/Open
    B1141(HFSM) Ignition Switch Low/Open
    If you get any fault codes let me know the number and I can check the test-fix in the diognostic manual
  • HogBag
    HogBag
    Check the brake relay under the left side cover. You can swap the relay with any of the others on the bike to see if you get your brake lights and cruise back.
  • HogBag
    HogBag
    Two tone
    Great news that it's sorted mate.
