Load Equalizer
  • phil
    phil
    18 years ago
    Just put LED indicators on rear was told I need load equalizer or thay would not work .Had them on for 3 days and no problems at all with no load equalizer. Will I have problems later or do you only need it if you do all four indicators. I have LED tri bar tail light as well if thet makes any difference.
  • Daggs
    Daggs
    I will be replacing my front and rear indicators soon, it seems that i will need a load equalizer when I do so just wondering which brand others here have used.
    The badlands one is one that seems common also came accross this one:
    http://chromeworld.com.au/index.php?main_page=product_info&manufacturers_id=10&products_id=1062
    anyway i guess i will need 1 for the front pair and 1 for the back pair
    cya's
  • BACAMICK
    BACAMICK
    07 dyna led on the front only  stock rear ,they flasht fast for the 1st few time but  now all good, had a on 4 11mths now , i dont use them verry ofter but
  • Robbo
    Robbo
    I'm running LED rear indicators and no equalizer on my 07 FXSTC for the last 8 months and no problem
  • FISH
    FISH
    Howdy Guys i'm looking for some mini bullet style in black to suit the night train any clue where i might find em , any info would be appreciated.
    Cheers Wayne
