Online: John.R
larger fuel tanks for nightsters
  • toxic
    toxic
    Since getting the nightster, besides it's rough ride, I am disapointed in the fuel range, so after a little research I have found a place who has already sucsussfully fitted a bigger tank to a fuel injected sportster. He said I could choose from the 4.2 or 5.o gal tanks, they use one piece tanks, not split ones.
    Will have to do the bars so they won't hit, taller risers & fatter bars maybe, not sure yet.
    Will post some more info when it comes to hand.
  • kingchops
    kingchops
    Hey Toxic, I'd be interested in looking at the info on bigger tanks.
    I know what you mean about the bars, I just put 4.5 inch risers on mine, did the trick great, now the bars clear the sides of the tank.  Here's a pic:
  • toxic
    toxic
    nice job KC, I spoke with some work mates 2nite who have had dealings with the same guy I spoke with, they said avoid him like the plague, he seemed genuine with me so will continue to look into it. Rough cost with out painting the tank was a grand give or take, depending weather ya git the 4.2 or 5.0 gal tank.
  • toxic
    toxic
    KC mate, thats a great page, went through it, found an '09 part # for the 4.5 gal tank to suit the XL1200N, needs a different seat, installation kit & probably some different riser's, but it would all come ready to fit, with Harley warranty.
    Will head down to discuss with the dealer 2morrow & see I I can't get em moving on it, once I get them to work out the finer details, I'll hit the U.S. web sites & see how much cheaper I can get it all for.
    Mate many thanks for that.
  • kingchops
    kingchops
    I just looked up the '07+ Sportster C tanks on M&M web site (www.mandmcycles.com): $487 US + shipping, damn their prices are good. If you get a vivid black or vivid black two tone you wouldn't need to get it painted either.
  • toxic
    toxic
    Thanks KC, Jilli, I believe the new tanks from Harley will be in the '09 big book of bling & other useless bits for Harley's, comming to a dealer near you soon, Jilli the tank you mentioned, what model did it suit as from what I've been told, no other tank specific to the Sportster range will go onto a Nightster for some reason.
    Thanks for the help
  • toxic
    toxic
    ok KC will have a look, went out riding 2day, had to fill up twice to get back home.
  • toxic
    toxic
    seems to be getting about 80k's for 4 ltrs, so looking for fuel stop around the 200k's mark, by that time the fuel lights been on for awhile.
  • dav66h
    dav66h
    THATS THE ATTITUDE JILLI ! with the xl custom tank i hav'nt pushed the issue to much ive got about 280 out of mine and when i filled up it only took 14 litres i think you should be looking at 300 the light comes early though after about 2/3 of a tank ive done 70 or so km with light on i guess it will vary depending on how hard everybody rides .
  • kingchops
    kingchops
    I just checked out the latest VTwin catalogue and they now have a couple of tanks in there for '07+ XL's, part numbers: VT No. 38-0877 (seems larger than stock),  38-0485 (smaller than stock?).
    see this page (bottom right tank on first page):
    http://www.vtwinmfg.com/catalogs/cyr/pdf/XLGASTANK.pdf
    Plenty of tanks in there for '04 to '06 so like I said above wouldn't be a far stretch to get these modified to suit an '07.
  • Oldman
    Oldman
    g'day all,
    just finished fitting a 17 ltr tank on the new 48.
    I got it from J&P landed in Oz  for $369.
    Had no trouble with clearances anywhere.
    Only thing was I had to buy new screws HD#1331 to fit fuel pump module back into tank.
    Looks good so far photos to follow soon (few weeks).
    Bob
  • 883n Harley Convert
    883n Harley Convert
    Love the jerry can strapped to the swag...................!! The 4.5 litre tank looks pretty good on the 48 though!
