Online: baldy1450
V-tune queries and files from Paulsails01
  • paulsails01
    paulsails01
    Hi Guys,
    Please excuse me but I am now using this post as a continuation of my  threads originally posted into the" Cal file thread" commenced by Ozroder.
    Hilly,
    if you are available, I just need clarification on your last post to me regarding your review of my last V-tune run Histogram, which I might add was most informative.
    With lowering the Idle RPM, you mean I should do this via the "Idle RPM"  table? would you recommend the 700 RPM adjustment be made from the 46 degree to say the 170 degree cells? what engine temp should I consider as the stop V-tune for this part of the map?
    I can see what you are doing to achieve the hits in those cells that are deficient of a decent count.
    This may be considered trivia but to those of us who are just starting out, the "Help" menu bar within the Mastertune file is very helpful, read inconjuntion with the stand alone Instruction Manual, the half penny is on the way down!
    Cheers Paul.
  • paulsails01
    paulsails01
    Ando, Hilly,
    Thanks for this, could have a cooler day to commence this today.
    Cheers Paul.
