Online: baldy1450
VIC EPA - Screaming Eagle II
  • JD
    JD
    shouldnt they pass ?
    Who dobbed you in Ebony? I was told you need to be dobbed in twice to get a notice (can be from the same person though I believe) and in most cases its a neighbour.
    I lay off the throttle as much as possible in my street, but there's a few bikers close so I'm fairly safe :)
  • HogBag
    HogBag
    Are you guys sure you need stock mufflers. I would fight this as all mufflers rust away over time and need replacement. If they are legal noise wise they should be fine ?.
  • Aussie XB12SS
    Aussie XB12SS
    No they don't need to be stock - they just need to be legal.
    I have a set of slip on Screamin Eagles Street Performance mufflers & I doubt they would pass any test. I don't think the words "50 state street legal" mean much to the EPA.
    You only need to be dobbed in once to get a  letter. Even if you have stock mufflers & some knob head rings the EPA & dobs you in then you still need to pass a noise test - guilty until proven innocent.
    & yes, of course the EPA keeps a record.
    Been there done that.
  • Taffymarsden
    Taffymarsden
     So I guess you are saying my SE2 s without baffles might be slightly over :) so far so good though and keeping my fingers crossed.
  • Soapbox2627
    Soapbox2627
    cant you go to an exhaust shop and have your bike tested without the EPA involvement.
    then you will know to change them for the official test or not
  • flacky
    flacky
    For me the easiest way would be put some stock mufflers on do the test and then change them over .
    Remember these pricks have nothing better to do and fighting with them will in the end get you nowhere .
    Show them what they want then change them back .
  • fizball
    fizball
    I asked the bloke who tested my bike why it's stamped 98db (ADR approved) on the swingarm when EPA states 94db. He said Harleys are allowed the extra 4db stock, but if you put aftermarket pipes on they have to be 94db. Rediculous!
  • RumDeluxe
    RumDeluxe
    Fuk - can you turn that the right way up.
    Been following this story with much interest.
    - - - but had to whip out and throw up when I got to the execute in court bit !!!
    You try reading this shit with ya head parallel to the keyboard on a belly full of rum !
    Good luck - is interested in how it all pans out for ya.
