Online: softfat
FORK OIL?
  • 666
    666
     ANY of you guys know the exact amount of fork oil to put in each leg on 2010 iron thx
  • terroristone
    terroristone
    401ml/13.6oz , Remove spring and preload spacer, compress shockers fully, pour in 401ml/13.6oz oil, then check that the oil level is 3.11in/79mm from the top. What i did was get a syringe and make 79mm from the end, place it in the shocker to correct level and suck out the excess from the centre of the tube.
    Regards Andrew - T1
