Online: softfat
PURPLE POLISH
  • Harvey
    Harvey
    :) G'day Dicko, so anyway did you end up finding were Marla is?:)
    I have bought a pressure can of S100. Good reports on it for bringing
    back the new black finish on the engine cases.
    :) And what happened was someone naughty?:)
  • Harvey
    Harvey
    Your at the top of Aus. Bully's over in the west and I'm in the east and
    Marla's in the middle.
    The moments gone now with Thread stripping and If you are typing while
    others have posted you miss out on posting.
    I need another drink rrrrrrrrggggggggggg
    Second attempt. I have now worked out how to overcome this problem.
    When I'm ready to submit I copy it then if it doesn't post I paste it and
    post again.
    Ha they can't stop me nowwww
  • Rocky2010
    Rocky2010
    Great stuff the Purple, have been using it for years now, its expensive but when you think about how little you have to use its worth ever cent. One bottle last a long time.
  • Harvey
    Harvey
    heaps quicker than autosol
  • Chris's Signs
    Chris's Signs
    i love the stuff...on the old shovel i wipe it on, let it dry (haze up) then wipe off...works great
    elbowgrease for the dull bits...
  • Rooster
    Rooster
    If you use Cali Customs de-oxidizer before you use purple polish it reduces the amount of effort needed to polish up the metal.
  • Harvey
    Harvey
    So does anyone use the Harley products?
    And how does it compare to these above?
  • deesy
    deesy
    Purple polish is $36 here in Dubbo. Got it anyway and I must say I thought my Fatboys rims where actually clean until I put this stuff on. They where filthy!! Tried tyre shine on the black and it has worked quite well. Will do till I can get some S100 anyway.
  • SoftailSteve
    SoftailSteve
    i used autosol on truck bull bar and fuel tanks work well
  • SoftailSteve
    SoftailSteve
    still sold and works well
