Online: Stuart
rear pegs on 48
  • 48fan
    48fan
    am thinking of putting passenger pegs on the 48
    any one done this ?
    pros and cons ?
    any advise apreciated
  • terroristone
    terroristone
    easy to do jase, i has a set one mine for awhile. The only downside is the pegs that they come with look like ass..
  • one_oak
    one_oak
    I use mine on the highway when its windy sometimes
  • PK2
    PK2
    I use mine a lot. But then again I have a broomstick bar.
    It is comfy though!
  • 48fan
    48fan
    Im thinking they must stick out ridiculously far to avoid the pipes
  • skirtster
    skirtster
    I have my rear pegs down all the time,great for cruising, for different seat position,or to give fallen riders a lift,
  • Bear2009
    Bear2009
    Easy as piss to put on , takes about 10 minutes , pegs look ordinary , buy some after market one that suit the 48 .
    The stock ones that come with the kit dont stick out too much but are butt ugly
  • COLONEL ANGUS
    COLONEL ANGUS
    you cant see a fricken thing in your mirrors with a pillion! and the right hand side is a prick to put on if you have short shots
  • 48fan
    48fan
    ended up getting 1 inch extensions from DK and the pegs now clear the pipes
    the right hand side is a pain in the ass
    thanks to Manny for helping me ,cheers brother
