Online: softfat
billet distributor
  • tonz1970
    tonz1970
    hi new help just fire the old genny shovel up, first time in 8 years, & i have put in  a billet disributor, but to get her running i needed to spin it around so much that the wires touch my cylinders they will melt if they stay there, ive seen pleanty of pics & the name plate is facing out , can anyone please tell me if they have the same problem, thanks tony.
  • DaveP
    DaveP
    Sounds like the dissy was put in 180 degree out, if you have just put it in then recheck. If it was in 8 years ago and running, thats another story.
    when you fit a dizzy  you work it as  so the wire's   & any other bit's  are not in the way of anything + also when set the adjustment should be in the middle range  or there abouts you time it of * 1 cly that is the front on a harley
  • tonz1970
    tonz1970
    thanks guys, yea i took your advice & spun it 180 & she runs a whole lot better lol i feel like a dumb prick lol
