Online: Soapbox2627, B0nes
94 sporty. NEED HELP
  • hayzy
    hayzy
    Hi guys, Im new to this site and have been looking around and love what i see! some real nice bikes out there!
    Was wondering if anybody knew if VANCE & HINES 2 into 2 big radius would fit up on my 94, 883 sporty? I have had the bike a little while now and has been a work in progress.  Some shops have told me they will fit but with bracket adjustments. Would love any feed back.
    cheers Hayzy.
  • wildkatze69
    wildkatze69
    Not a techies but check the V&H website and write them an email. They are actually pretty good and do respond to queries.
  • hayzy
    hayzy
    righto mate i shall email them. cheers
  • kingchops
    kingchops
    The V&H Big Radius for Sportys are only designed for rubber mount moderls, i.e 2004+.
    There are some pipes that look very similar made by Bassini which do fit older models.
  • hayzy
    hayzy
    Yeah i just checked them out. Think your talking about the bassini sweepers. Not to bad but i really have my heart set on the v&h. Just love the look so hoping there is some way i could make them fit and if so what that way is??
    What is the main difference when it comes to the pipe fitment on the newer models?
    Yep, you have to make a new bottom bracket
  • hayzy
    hayzy
    thanks guys. So I wont be wasting my money buying them? i can deff make them fit? The bike didnt have stock pipes on it when i bought it, Has some home made looking pieces of shit that have been cut with a ruff grinding attempt with jagged edges. wouldnt be surprised to hear who ever done it took his leg off in the process..Walka when you say bottom bracket do you mean the rear header bracket? or is it a support bracket? the pipes on it dont have any brackets on them, there just bolted to the heads..sorry for the stupid questions haha my first harley!
  • hayzy
    hayzy
    ah all good! found the stock mounting point! i'll make it work! thanks for the help boys..
