wet sumping in old iron head
  • 74 Iron Head
    74 Iron Head
    Hey guys,
    woundering if anyone knows of or has applied any solutions to the wet sumping problem in old sportsters,I have a 1974 sporty and it wet sumps kinda bad if left for a month or two with out riding,usually just put a pan under the blow by pipe to catch the oil,but what a pain in the ass!
     happy new year John,   i can not kick start harleys  after being brought up on those early cast iron kicker only XLCH  sporty's as  i,ve had a few opperation's on the old kick start knee  about 10 times on crutches  , those early maggie's are stuff  & old now  there was only 1 good electriclan that knew how too repair them  all the other's were hopeless,    but he's 85yrs  now that was little ray i use too race his 1951 AJS for him back in the 90's.   i can take her on but  a bit busy ATM only if he go's for a dissy with & electronic ign  + battery other wise it's realy a waste of time,                             you will be wearing his knee out,   the maggie run's off the cam  @ 1/2 crank speed the dissy is 1/2 time again off the cam that is only about 1/4 rev per  crank rev fo the maggie , the sporty kicker only turns the motor  just BTDC too ATDC not enough turn too spark a light esp with & old maggie thats lazzy , i can look after  her only if hes keen]
    those early kicker gears are badnews as they wear-out from use & then slip & stuff your knee/leg  great fun , a real mans bike ,
    my late model harley kicked -back the other day & broke my thumb off the handlebar starter button,  fuck that hurt
  • 74 Iron Head
    74 Iron Head
    Het thanks for the info guys,well looks like ive got some work to do then,reseat the check ball n stuff.
    I was just wondering if you can route the oil line back into the oil tank or does it need to be left open at the end to suck air back in?  mmmm..might make a small oil catch can for it maybe
    stuff M8,   i hope them chinese can drive them dragons better than they can drive a car
  • Wimbo
    Wimbo
    So what do you think about that DDR59? :)
  • 74 Iron Head
    74 Iron Head
    Do you have a link for the eBay posting Tom?
  • brash
    brash
    haha my evo based chopper does this all the time, I consider it an oil change, just top up what comes out.
