Bags for Iron 883
  • Laps
    Laps
    Hey,
    I did a bit of a search and found some results, however, I think I'm after something a bit different.
    I basically want a saddle bag of some sort that I can attach if I want to ride to work or something and put my lunch in... BUT I want to be able to remove it without any traces if I want to cruise or whatever...
    Does anything like that spring to mind? I'd also like it to be black... The other threads didn't really mention removal etc.
    Thanks!
  • multinut
    multinut
    Try the plunderdogs (plunderdog.com)
    i have a set that i keep on my nightster permanent
    they are unobtrusive and suit the look of the bike
    they come off with no trouble
    Hope this helps
  • Fire511
    Fire511
    I made up a bracket that skrews into the pillion bolt holes on the near side of my 48 (so would fit a nightster) for a solo bag, then I got it chromed. I am now just waiting for a saddler to make the solo bag. Much cheaper than a harley product and much bettermade. You can then get something that fits perfectly and wont rub your bike. All up the solo bag and chromed bracket will cost me $220.
  • one_oak
    one_oak
    I use to have those Plunderdogs on but found i couldn't hold enough for work etc, Looks good on the bike but doesn't hold much.
    I ended up installing this bag: http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=37&postid=406058&view=topic
    The other thing you might want to try is a tank bag laps or a sissbar bag and just use em when you need, i still use my tank bag when i need the extra space
  • Laps
    Laps
    Thanks for the responses!
    Those plunderdogs look the goods... Do i need to take the seat off to install / uninstall them though?
  • multinut
    multinut
    Laps
    yes you do need to take the seat off
    if you get the harley seat thumb screw its easy - no tools required
    have a look at all the pictures on the plunderdog website
    there is also a youtube of the installation of them
    yes they be a bit small but you can fit quite a bit into them
    and if you want something bigger just drop pete a line he does custom work and the craftmanship is excellent
    there are also a heap of pics on facebook (nightster owners group)
    Multinut
  • wildkatze69
    wildkatze69
    Just got an email from plunderdog. He also makes a single bag which is not on his web site y.et. Looks great
  • 666
    666
     show us pic wild
  • wildkatze69
    wildkatze69
     here we go
