Help please
  • gragra38
    gragra38
    I just picked up my '07 1200 Custom last Saturday, and while looking over everything the last few days I've noticed that the gap between the rear tyre and guard on the left hand side is about 1" may be 1 1/2" but the gap on the right side is about 1/4". I've done about 500 ks since I got it, and it rides beautifully, no wobbles, shakes or anything  like that, so I guess the rear wheel is straight and true. is this common? am I in for some trouble? what could be causing it? ps. I have only checked it on the side stand, bit hard to hold up straight and check by myself. Any advice would be appreciated. Cheers, Graham.
  • HogBag
    HogBag
    I would check a few bikes on the show room floor around the same year and see how the wheel lines up in the guard. I would also run a string line or a straight edge from front to back wheels and see how the alinement looks. Make sure ithe front and back wheels are square. Did you buy the bike from a dealer ?
  • gragra38
    gragra38
    Thanks I'll check that out, yeah I bought it from a dealer so I have warranty.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    not sure as never had to check em before but alot of the early soft tails had the front wheel 5mil off centre to the rear an if ya ran a string line it would be out but they all went threw ok an handled great once rear shocks were stiffened up have had a few bikes that were bent from factory as well over the yrs had a fxd 2002 which was nearly 6 degrees outta wack from the factory only found out when was pulled down to fit new swingarm bushes ..id ask ya dealer about other sportys as hogbag says an if they ok an diff to yours ask to get it checked for frame straightness
  • gragra38
    gragra38
    Thanks, will check with dealer on Saturday.
