Online: B0nes, Stuart, Hilly
steering lock
  • dkr059
    dkr059
    Hi folks just a quick one,
                                           I have lost the key to my steering lock, its not locked, does anyone know if I can get a key cut for it ,or is it a major,
                           cheers and beers D.K.
  • dkr059
    dkr059
    Your a genius red,
                                    thanks for the great advise on the wheels and as well your an expert on the steering lock, thanks mate can hardly wait until I have another problem, you will be able to a bit more of brilliant advise,
        cheers D.K.
  • nobody
    nobody
    Any locksmith will be able to cut a key for the steering lock,I had one cut for my evo.But as mentioned,you are better off getting yoursefl a good quality padlock and putting through the holes,and not one of those cheap brass lockwood padlocks you would use on a gate,as they cut them in 2 seconds and are gone.
    nobody
  • dkr059
    dkr059
    Thanks red, that price for the wheels wasn't as bad as I thought, as I live in Darwin cost will possibly be more due to not a great deal of shops up here, and the lock thing I know that they are basicly a pretty p#ss poor set up but if its there I like it to work guess I'm just a bit of an old mole like that, just the way I am.  cheers again D.K.
