Sugestions for suspension for 05 FXDL?
  • Ozbernie
    Ozbernie
    Advice, feedback and opinion for best suspension upgrade for 05 Lowrider?
    Currently running Progressive 418 series. Harsh and ineffective.
  • Oldman
    Oldman
    Have a look at the new Progressive 970's.
    They are the same as the Ohlins.
  • guzzi4v
    guzzi4v
    I have Ohlins front and rear and a true track.
    I think I replied to you on another forum saying I genuinely believe the True Track stuff is well and truly worth the money if you ride hard.  People will poo poo that but I stand by it.  I noticed the difference.  I will have my Fat Bob for a long time but I crack a smile every time I look at that swingarm attached to a rubber mounted engine.
    The Ohlins are better but I can't say how much better yet because I had some set up issues.  Basically both ends were undersprung as sent so I had to get it sorted out.  This has been done but I've been O/S for a few months and haven't ridden the bike yet.  I can give you an honest opinion on it when I get back at the end of Feb.
    Is it rude to ask where you are?  If you're around Brisbane you might be able to have a look at it yourself.
  • Ozbernie
    Ozbernie
     Hey Guzzy4v,
    Im in central Victoria. Thanks heaps for the offer but distance might be an issue :)
    Still unsure what way to go! Need to do something soon. It's like I'm riding a rigid with rear shocks!
  • jacko88
    jacko88
    reasearch the race tech straight rate springs for the front with emulators, steering damper and true track, Icon have a similar sytem to Ohlins at a cheaper price then you will eat up the miles in comfort
