Power Commander
  • Tweakit
    Tweakit
    Hi Guys,
    When I bought my Vrod I got handed a bag with a power commander 3 in it, being a newb I said sweet but why is not fitted to the bike??
    The reply was the the guys got a better map/tune on the factory computer so they took it out.
    My Vrod has naked air box and Vmod mufflers....
    A couple of questions,
    Should I have the PC3 fitted?
    Is there any major difference between PC3 and PC5?
    I was told not to bother with changing the cams out, but replace the throttle body with a larger one as that  would work well?
    Im not after something crazy but just a little more snappier...you no.
    Cheers for any help you can offer.
    Damien
