Indicator mirrors
  • deuce2004
    deuce2004
    Just had a set of HD led indicator mirrors fitted to my ride
    Very happy they are a lot brighter than the factory indicators and it tidies up the front of the bike by removing the factory ones
    Craig
  • Isaac
    Isaac
    I like that idea; I don't think that'd suit my old-ish lookin' Springer but if my bike was a 'modern' I'd probably give that a go. Any pics?
  • deuce2004
    deuce2004
    Will take some pics tomorrow and post
    Craig
  • deuce2004
    deuce2004
  • deuce2004
    deuce2004
  • deuce2004
    deuce2004
    Hiya mate
    I think they were about $385 and about $200 to fit
    My service bloke also had to wire a box to make them flash normal
    Well worth it it really tidies up the front of the bike
    Craig
  • Isaac
    Isaac
    Looks good.
  • Isaac
    Isaac
    LED's would look nice on black too.
  • 883n Harley Convert
    883n Harley Convert
    I've got them installed on my Iron, they look great and work really well.
  • Bunyip
    Bunyip
    Where from Waz? They go ok on Sporty?
  • terroristone
    terroristone
    I looked into these for mine, and after some measurements and a few photos i think the stem of the HD led mirrors are way too long, well flipped on a sporty anyway, i found a set on ebay that look better, i'll get a picture soon.
    T1
  • terroristone
    terroristone
     top mounted and crome they look fine, such as yours, for my Iron i looked into them, in black and when flipped they hany way too low from the bar and look abnormal to me. $300 odd dollars for HD ones and $29 for mine, if the stems were shorter i would have got the HD ones. If harleyconvert can post a front on pic and i'll do they same so you can see what i mean.
    T1
  • watto883
    watto883
    anyone else considering this could use factory mirrors off the MUSCLE .... little different with LED's in the stems and you can change heads over for something smaller ..... just a thought !!
    883n Harley Convert
    Its a shame they're not black Watto, they would be brilliant!!
  • watto883
    watto883
    Mine are , I painted them. ... Had a small blade looking head on them but they hopeless so put factory heads back on , black too
