Online: Stuart, Hilly
GOING SE 103 STAGE ON MY 2009 DELUX
  • RumDeluxe
    RumDeluxe
    Congratulations Thunder - am saving my pennies too.
    Plan on going straight from standard to the Stage 6 that HD is bringing out next year.
  • HogBag
    HogBag
    Is there anybody that can answer a question will the stage 4 burn oil
    If the motor is broken in wrong you could glaze the cylinders causing oil to blow past the rings.
    If you want to burn oil pour some under the tyre and bounce her of the limiter then dump the clutch.
  • Burraburra
    Burraburra
    Hey mate,
    My 2009 Softy Custom has had the 103 / Stage 4 inserted about 3 months ago.
    I have done around 4K since then; oil dumped after 1K, soon to get another relaod of oils.
    No excess oil usage with my ride.  Nor did anyone say I should watch the oil levels for excess usage.
  • thebald1
    thebald1
    Thunder ask Ando, and see his posts Re my question re 103 stage IV
    cheers TB1
  • Burraburra
    Burraburra
    Thunder,
    I am extremely happy with what I got for what I paid for.
    I aint no spanner man - so no use me getting bits and pieces and doing it me self.
    Once I picked it up all the main thing they wanted was the bike back around 1000 ks time to dump the oils.
    Also, asked me to treat it kindly for the 1st 1000ks.
    Another point, the 103 Stage 4 wants to be ridden not chugged around on.
  • Burraburra
    Burraburra
    Ando,
    No mate, not soft on the bottom end at all -
    Just trying to say that I have found that the upgrade dos not like cruising.  It likes to be pushed along.
    (hope I explained that ok)
  • thebald1
    thebald1
    hey Thunder, give us the low down,
    How was the build, are you happy with it, was it all you hoped for?
    come on, share the love man
    cheers TB1
  • thebald1
    thebald1
    WTF , where is Thunder?
