Load Equalizer
  • Bloodnut
    Bloodnut
    Just changed all my indicators to LED Bullet style indicators, all wired up & running. BUT, I have a Kuryakyn Load Equalizer to install to slow down the indicators, buggered if I know where to either splice it into or plug it into.
    The bike is 07 FXSTC, taken the seat off, looked at manual,  but cant seem to locate any plug & play spots for Equalizer.
    Does anybody know how install one of these? Better still, any photos of where to splice or plug this thing into?
    Thanks in advance.
    Bloodnut
  • Crowy
    Crowy
    something like this from memory
    Under the seat...splice Purple from load resister to purple indicator wire
    ...........................splice Brown from load resister to brown indicator wire
    ...........................Black wire straight to battery NEGATIVE
    The Purple & Brown wires are your right & left indicater wires
    hope this helps
  • Bloodnut
    Bloodnut
    Thanks Crowy,
    Wired the Equalizer into front indicator loom. Bloody hell the Equalizer resonates a lot of heat when in use!
    It will be interesting to see how long it lasts, it gets stinking hot!!!
    Thanks again.
    Bloodnut
  • Sparra
    Sparra
    Maybe that's why some of them say that they are not to be used for hazard lights...
