Best Dyna Black Motor Cleaner
  • Bugger
    Bugger
    The Best Dyna Black motor Cleaner after giving your bike a wash is,,,,,,,,,,,,,,, Mr Sheen,,, just spray the rag and rub it into your black alloy finish,, it works a treat and last as long as the next time you get court out in the rain.
    It has a thin film of wax and brings back that black luster new look.
    In return Im asking you guys??  what is the best wash to wash your cycle in,, I have a denum ( matt Black) fatbod.
    I know not to polish it and windex ( window cleaner) works a treat for the tank & geards for the denum.
    I'm looking for the best wash that takes off bugs and dosent leave a smugy film, needing more hard work to get off.
    Whats the best  wash to bath your bike in ???????
    Also the best conditioning for alloy wheels, thanks in advance.
  • Aussie XB12SS
    Aussie XB12SS
    I use Morning Fresh dishwashing liquid on mine.
    Also use the cheap "Wet Look Tyre Shine" from Supercheap on the motor. Bargain when it's 5 for $10
  • Daggs
    Daggs
    +1 on both those products
  • Bugger
    Bugger
    I friend of mine with a streetbob recommendes Martech- Bike Gel its specially formulated for motorcycles, has a corrosion inhibitor its a consentrated gel, .
    You get about 40 washes out of a 1 leter bottle,,, only need 2 caps full in 3/4 a bucket of warm water
    costs $12.50 sold @ some good bike shops
