Luggage rack attachment
  • Dermie
    Dermie
    I have a 2005 Sportster 1200c
     I am thinking about making (getting made) a luggage rack. I have a sissy bar attachment (not harley- home made) alongside the seat fixed to the rear guard/shocker arms. It has 2 x 12mm sockets in it to take the sissy bar. I would like to attach the rack at the front  to the sissy bar & at the back to the number plate bracket. It would slope at the same angle as the rear guard so that the lines at the rear of the bike keep that sort of sloping to the bigger rear theme.The number plate bracket seems quite sturdy & the mudgaurd that it is attached to seems strong too, how much weight do you reckon it can take, 20kgs ??
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    last rack i made held all my mates belongings about 60kg so you should be ok if ya have it held on with enough bolts ect an if ya make it out of decent thickness metal i made hhis outta 20mil x 20 mil square
  • Dermie
    Dermie
     Ol Skool
    Have u got an idea as to the type of rack I am looking for & if so have u got any idea as to what you may charge to make one??
    Probably out of s/s.
    I could send you a sketch if thats the sort of thing u do.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    yea draw something up an post on here or in pm if ya want stainless be ok but i can powdercoat as well up to you
  • Ross
    Ross
    Dermie, if your in Albury, I've got a local stainless fabricator who helped make the rack for my sporty. PM if interested.
  • Dermie
    Dermie
     That would be good Ross, I cannot seem to see how to pm you!!
  • Dermie
    Dermie
     Thanks steamer I looked in the how section & followed the instructions there, just as you were sending your help to me, great thanks.
  • chriso
    chriso
    hey ol school, not sure if you can help or not but am hoping somehow to put a detachable rider backrest on a fatbob. not sure if there is anything out there as i have not really looked into it but just reading the forums and thought id ask the question. the setup im after is the same as the street glides have where i can just pop it in and out when needed.not sure if you know but they also adjust back and forth. it wont be used often but i do some big miles occasionally and would just give me a bit of added comfort when i do. If there is nothing on the market like this do you think it could be done and if so could you do it or know someone that would?
    Maybe someone out there knows of something on the market?
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    wat we used to do an some the mates still use em was basically turn
    9im talkin evos but twinkies could do same)the standard type pillion rest brackets you bolt to guard bolts ass about so the sissy bar/back rest was behind the rider when i was riding i used to do cairns from brissy straight threw an adelaide as well only piss n fuel n smoke stops if you can get a complete sissy bar setup or even make ya own as all they are is some 4mil plate cut to shape an either chromed or powdercoated
