Diamond Black Foot Pegs Help
  • Laps
    Laps
    Hey guys,
    After a bit of advice - Looking to get the Diamond Black collection footpegs and shifter, however a bit confused about some of the varieties... Can somone please tell me the difference betweent the two following pegs, the website doesnt really explain:
    Diamond Black Collection Footpegs
    www.harley-davidson.com/gma/gma_product.jsp
    Diamond Black Collection Footpeg with Styled Wear Peg
    Thanks guys!
  • 883n Harley Convert
    883n Harley Convert
    The variance is in the width of the peg, the top one pictured above is about an inch in diameter and the second picture ate about half the size in diameter. Went thru the same thing myself, i ended up with the fatter set! On a side note, i found that they wore really badly in a short period, just wearing boots.
  • TC883
    TC883
    I got the ones in the bottom pic on my Iron. Took the wear peg doinks off for a cleaner look. Work fine, and I figure all pegs will show wear over time. TC
  • Tzukius
    Tzukius
    883n Harley Convert can you elaborate on what you meant be "they wore really badlly"? I recently fitted the smaller diameter pegs (the ones without the wear bolts) and couldn't be happier.
  • Laps
    Laps
    Ah k, so its just a different style... I was wondering what the thing sticking out the bottom of the second peg is, so its to stop the peg hitting the floor around corners etc? Does anyone know if the prices on the harley website (approx $80 depending on style) is for each peg or a set?
  • Laps
    Laps
    Can someone please explain what the wear peg actually does lol?
  • TC883
    TC883
    Yep, the wear pegs are supposed to touch down first to warn you how far you are leaning. With my Iron lowered with 11 inch shocks, the lower exhaust on the right and the side stand on the left touch down before the wear pegs, so I took the wear pegs off. The longer wear pegs in the photos would probably work, but they look crap. IMHO.
  • TC883
    TC883
    ..and then ride it!! TC
