Online: speedzter
Fork gators on iron? Can u take em off??
  • iron14
    iron14
  • Rocky2010
    Rocky2010
    Or if you don't require them later just cut them off, this will avoid all the work taking the front wheel, front guard and the brake caliper off. But im not sure if you need to put on the chrome caps over the fork seal. If so you will need to purchase the covers, then you will need to take of the the front wheel, front guard and the brake caliper off then remove the forks from the triple clamps.
  • TC883
    TC883
    Why? They look great and suit the style of bike. The fork gaiters were one reason why I got the Iron in the first place.....
  • iron14
    iron14
    I dnt like the look of em. Dunno just my oppinion and no one really takes em off so i thought i would
  • iron14
    iron14
  • MattH
    MattH
    Go the butch mate and cut 'em off, then you'll find you ain't got no dust covers, so you'll have to pull them to bits anyways!
  • Bunyip
    Bunyip
     Mate, where did you get em for $37? The Peter Stevens guy wants $57 for them? I need a pair, and was going to go US? Would love to get some for $37.....
