cleaning loctite
  • Train
    Train
    stupid question fellas.
    Can someone tell me what they use to get old loctite out of threads
  • AJ56
    AJ56
    I used a wire wheel on a grinder, and for the hole a bolt with the same thread with a V cut along the thread using a file to clean the threads
     i clean the bolt  with a little screwdriver in the thread  or a thread  a file,  the threaded hole i blow in it with the air gun of course & use a little bottle brush with wd40 , heat will normaly loosen loctite
  • Daggs
    Daggs
    Bolt, wire wheel or brush, run a tap down the holes, use loctite primer as well
  • wayne.craft
    wayne.craft
    Tap and Die set only way to go...
  • Train
    Train
    Thanks fellas, i was mainly wondering for in the holes ... thanks for the tips.
