rear shocks
  • jocky
    jocky
    hi people,.just a quick question about suspention,rear shocks to be more procice.
    i am looking at replacing my rear shocks on my widey 2010, like the progressive 412-4041c full chrome cover 11inch.
    standard shock is 12 inch, my question is do all you gooroos no if i have to do anything to the front springs?.
    will i upset the handling of my bike lowering the rear and not the front?
    help appreciated...
    jocky
  • gsh
    gsh
    lowering the rear 25mm will not affect the handling too much. Understandably it will be a little harder and your cornering is a little less. There are a lot here that have lowered the rear only on softails and conventional shokies. I once lowered mine 65mm at rear only, it was embarrassing going around roundabouts and got a little wallow on long sweeping bends. Lifted it up to 40mm and it fixed the wallowing. On my next Harley I only lowered the rear 25mm and didn't notice much anything.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    as above not much diff but while ya at it change front fork oils so ya know its all new may stiffen the front just a tad
  • DaveP
    DaveP
    Will you be riding 2 up much? the 11's can be an issue on some roads with someone on the back. I find 11.5" shocks are very good, currently using Progressive heavy duty 440's with no issues. As mentioned by Ol Skool change your front fork oil as well, I went up to a 30 weight grade and its pretty good.
  • DaveP
    DaveP
  • jocky
    jocky
    hey davep, no iwant be 2up at all, plus iam only a little prick and only 75kg, so if i lower it the full inch do you think it will be ok?.
    pluss want it as low as i can safley.
    jocky
  • DaveP
    DaveP
    all good then mate, I personally have not found any issues with handling over the years by lowering, just cant lean her over as much is the issue you will face.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    i had 11 progressives on back my twin turbod fxr had 18 inch ackront rim x 4 inch on rear with 21 front an wideglide conversion handled great even with lisa on the back i was 110kg then an she was 49kilo lol best thing was it got power to the ground quik as
