bullet style headlight advise
  • 48fan
    48fan
    Hi guys and gals ,am looking to put a bullet style headlight on my 48 ,have had a bit of a look on the net but it does my head in .
    VPW has one at about 250 but I was hoping for something cheaper (times are tough),can any one make a suggestion or provide links to anywhere that might be of help to my mission .
  • Burnzi
    Burnzi
    I bought a cheaper one mate, the rust started as soon as i opened the box, shoulda gone for Walkas.
  • Burnzi
    Burnzi
    Outer shell is perfect but the insert (which I cant work out how to remove) is shit.
  • Gilesie
    Gilesie
    there threaded on Burnzi, prolly has a bit of loctite on it
  • 48fan
    48fan
    I see the billet alloy stuff is dearer ,so must be better than the cast alloy and be stuffed if I know what abs plastic is but its cheap and and shiny and Im guessing wont rust .
    definitely like the look of the deeper wider ones (lol again)
    still gotta figure out what will fit up the easiest with out any modification .
    but am getting closer .
    Call me tommorow and I will give you a Deal on one, Our's ADR Approved , have High Beam, Low Beam, Park Globe and Glass Lense
    Not Plastic
    , We would have the Biggest Range of Custom Billet Headlights in the Country and the Best Quaity, There are made by the same Company that make them for Arlen Ness and HD's Aftermarket Range, Our range is a mix of the two. and 1/2 the price, To be honest most of the HD Dealers buy them of me.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    i can powdercoat ya one you already got man or if you can get a second hand chrome one i can do that in satin or matt black just a thought
  • 883n Harley Convert
    883n Harley Convert
    After a little searching, guess what I found a 48................I like it!!
  • 48fan
    48fan
    i like it !
    but
    two weeks ago I would have been totally into it
    but
    am looking at something with the missile shape and a peak
    but
    i do like it hmmmmm
    dammit
    always good to have options
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    must admit looks good the big lites fill the hole well
    883n Harley Convert
    Check this out as well.........
    883n Harley Convert
    Not convinced with all of the mods he's done, but I do like the headlight
  • 48fan
    48fan
    lol Im smasghed
    883n Harley Convert
    Just on the VPW website, they've got a 6' that would work really well! Just that little bit smaller, but same effect!!
