Blinkers
  • Sparra
    Sparra
    18 months ago I got some smaller blinkers for my 1995 softy...They where supposed to be the globe type and would work without too much bother. When I connected them up they just stayed on so I am guessing they are led as I can't see how to change the globe in them...I just put them back in the cupboard but might give it another go..Is it a simple job to connect an equaliser or is there another way???
    Cheers...Sparra
  • Sparra
    Sparra
    Thanks lads...I will chase one up..A pic would be good if you have time...
    Cheers...Sparra
