Front forks on XL Low
  • sportbobber
    sportbobber
    Having a little trouble getting a good answer (even from my HD Dealer) on how much shorter the fork legs are on a 2007 Sportster Low than a normal Sportster. By eye I'm guessing an inch... I've had 3 previous Sportys and I have to say HD's idea of adequate ground clearance and mine are different! I'm going for another 3-4 inches to kick it up a touch (and look cool) and an answer on this would help me with ordering the right length for the replacement tubes.
  • grafpak
    grafpak
    just measure yours!!!!
  • sportbobber
    sportbobber
    yeah, OK, I just thought a simple answer would save me having to pull the effing things apart before I even get the new bits to throw on ... still, it seems like I'll have to go that way.
  • sportytrace
    sportytrace
    Well since you offered to do the hard yards ;) When you do measure.... can you let us know the answer!
  • grafpak
    grafpak
    what about measuring from axle to top triple tree on both bikes that will give you the difference!!!no need to pull apart!!
  • grafpak
    grafpak
    tru sportyrace , but if you get a rough idea off the height difference say 2" lower and you replace your own bikes springs 2" lower you have to get the visual look your after!..dont no if i explained that right..
