any thoughts on a 87 sporty, 1200
  • muza
    muza
    g'day all, only new here.
    looked at an 87 sporty today with a 1200 engine, yes a 1200, matching numbers.
    wide glide front end, very good paint (painted about 4 years ago, but looked after) forward controls, softail handle bars.
    has a slight oil leak at the bottom of the push rods but am assuming its only a gasket.
    that was about all i could find wrong with it.
    the bloke wants 6k for it on the road, reg till april.
    very neat and tidy bike.
    any thoughts would be appreciated.
    cheers muza
    The 5 Speed Bikes are the one's to buy,
  • Shedrat75
    Shedrat75
    I bought my 91 1200 sporty for $5000 in pretty good condition .should beable too get him down lower as the guy had $6000 on mine
    keep away from the 1986-1990 sporty's could be a bit of trouble if unluckly
  • muza
    muza
    what sort of trouble is common on these first 1200's?
    its only done about 45000k's which i didnt think was too bad for a 25 year old bike?
    cheers muza
     the g/box couintershaft  can break in half & smash thru the cases, the clutch does not have a nut holding it on & takes out the alt ,  + the main pinionshaft on the crankshaft breaks off  & stuffs the hole crank , apart from that there a good bike , they fixed all this on the 1991 up 5 spds models
  • crackers
    crackers
    Hmmmmm That gives me something to look forward to
