lowering shocks for iron
iron14
does anyone know how low the harely davidson lowered shocks are for the iron?
TC883
I think they are 11 inch. The stock shocks on the Iron are 13.5 inch. I have the 11 inch shocks of the 883 low on mine. They are ok for the money, and improve the looks of the Iron heaps. TC
883n Harley Convert
I've got them, TC is right; they're 11's!!
iron14
cheers mate, i rang every dealer around me and they couldn tell me. cant wait to get it first ride will be from bundaberg to emerald so hope they are still comfortable, can ya get 10s from anywere??
TC883
The lowest I have seen are 10.5 inch. Burley slammers are 10.5 inch and I think VPW forum sponsor also have 10.5 inch as well. Send a PM to Walka and I am sure he will help you. TC
iron14
Oh ok thanks guys might stik to the ones the dealer is putting on and maybe source some lowering blocks. Does anyone know were to get em from apart from ebay???
iron14
Cheers mate i looked. On there site and bought some 3 in adjustable lowering kit. 46$ all up with shippin!! Might run it at 10" and see how it goes. Are the ridgid ones too bumpy??
iron14
Yea sorry thts wat i meant. I got the 11,s put on it and i bought the lowering blocks for novelty. Its pretty bumpy in central queensland so i need some travel i guess.
