Heavier spring for rear shock
  • oneball
    oneball
    Hi all...Does anyone know if you can fit a heavier spring into the rear shocks on the soft tails[fatboy low]?
    I cant see why a spring couldnt be hanged over to a heavier one.What concerns me is the avaliability of a spring.
  • oneball
    oneball
    Hi all...Thanks for that Steamer.I will give them a call tomorrow.
  • oneball
    oneball
    Hi all...rockerulz,Who done your spring.???
  • oneball
    oneball
    Hi all...Steamer,Ive been sussing out the progressives among others.
    As soon as i double on my fatboylow,my bike bottoms out everywhere.
    Do you think the progressives will sort out the bottoming out problem?
    Are they a much better shock than the stock ones?
    Do they come with different spring weights?
    Ive got to ring Ikon again tomorrow,The tech was out for the day.But the lady i spoke to mentioned they can get a spring custom made,They also revalve the damper.Sometimes modified shocks can be better than aftermarket shocks.Ive got so much to consider.
  • oneball
    oneball
    Hi all...Thanks again steamer.Another quick question,Have you lowered your bike or is it standard height?
    I spoke to the tech at Ikon today.A modified shock with 20% heavier spring and upgraded damper $720.00
  • oneball
    oneball
    Hi all...Got a quote from M&M on the Progressive 422 RAP delivered to my door,$719.00.
  • oneball
    oneball
    Hi all...I bit the bullet and bought the Progressive 422 RAP shocks.
