what to do
  • JD
    JD
    going to up grade my  motor so the question is to go 103 or 110 not sure , now for the fun bit going to do the work myself never really done much with the tools before so should be fun.
  • JD
    JD
    is it hard to split a case ?
  • harrysboy
    harrysboy
    JD, yeah splitting the cases is easy, case boring is the trick (are you tooled up for that!!!). The 110 set up is pretty much obsolete now (even the CVOs will likely go to 120), not a lot of options with it, HD doesn't list it as a kit any more (113 is better as it can be stroked to 120).
    As the others have said, either keep your cases and add on top for 103-107 build (of whatever type) or consider upping the crank (with your or new cases) for 117-130+".
    I had the 110 done from new which was easy for the builder, have it running nice now (after minor mods) but will soon be doing the bottom end up for a 120 (sell on my 110/96 motor), so think seriously about the 120 kit if you are starting from 96.
    Have fun with your research and build. Lots of experience here on the forum (OZ and US) with bigger motors. Cheers.
  • JD
    JD
    see want to do it myself so its not so much how much power do I want its more what can I do myself ,I think I could do the 103 kit myself not sure the 110. as for tools what I dont have I will get the right tools are the most important thing to do a job
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    you can do the 110 yaself easy jd all ya need is good sockets spanners ect ya dont need presses ect but remember the heads DO need some extra work done one my bro heads on his 110 bout 3 months ago an got him an extra 12hp for small cost of 400bucks
    upto u to go wat ya want as you said its a must do once in ya life hey i done it wen i was 17 an now doin shitloads sometimes wish i had a normal job lol i reckon a 110 will keep u happy the bro bike does some serious numbers at townsville drag strip an gave me a big surprise
    theres an old sayin in the drag an race society SPEED COSTS MONEY HOW FAST DO YA WANNA GO ...cheers
    or ya can do wat me n mate done few yrs back go 148cubes lol
  • FXSTC 09
    FXSTC 09
    i went down this same path not long ago tossing up where to go next and went from stock 96ci to an S&S 106 kit and it was fun at first but you soon start looking for more.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    yea true stix but he can do most stuff we all gotta get some machineing done but i reckon 110 even though not popular is a good medium range build
  • Dan
    Dan
    Thanks, I totally agree!! yeah the figures look good and probably the best value horsepower that I have been able to find, its a pitty I cant find anyone locally to do that sort of work for that sort of layout
    From what Ive found its almost worth sending the bike there to have it fitted for under 2k than it is to get it done here
    So I guess IF I can find someone locally to fit it (Im kinda tempted to have a crack myself) all I would need is another dyno tune??
    Dan
    I must be getting skeptical in my old age, but some of those FM dyno numbers with stock heads are amazing ?
    I've done a 103 with Wood TW7 (similar to the 555/777) with Hallam heads, and it's nowhere near those TQ numbers.
  • simmac18
    simmac18
    Have a real good look at the figures for a 113, bolt in new cases and heads, whatever you go make sure you give the motor good flow, it makes a shit load of difference. The 113 will give you a good base to start with. I have been having the same discussion with a mate with a Street Bob who is considering a 103, but now looking at the 113. Spoke to a good mechanic the other day who does plenty of upgrades and has done a few 113's and 120's he prefers the 113. You've also got to remember to get the right cams for your build, you'll want some high lift cams with plenty of top end punch, don't worry about the low down torque, you increase in HP will take care of that. have fun.
