no blinkers
  • jungle
    jungle
     both blinkers not working. when i start the bike the red key light on the dash stays on ,first it was only right hand blinker now its both, has anyone got an idea what the problem is, cheers jungle
  • Crowy
    Crowy
    Some-ones got to ask the OBVIOUS question
    So it may as well be me
    Have you checked your oil & bulbs....?
  • jungle
    jungle
     yeah thanks man ,all good that end
  • Ray
    Ray
    I had asimilar problem recently on my 2010 wideglide the left hand indicators wouldnt work and when they did they would not cancel. This occurred after the bike spent a couple of nights outside in some bad weather and condensation got in everything even the speedo about a week later it seemed to fix itself (dryed out)
    Just a possibility
  • Gidgee
    Gidgee
    Hey Jungle. Just had a similar problem mate. Check your fuses. My tail light bulb was broken, condensation entered the actual housing in heavy rain and must have shorted. Fixed that and the fuse stopped blowing allowing my blinkers to work.
  • jungle
    jungle
     fuses all good, bulbs ok, got me stuffed
  • jungle
    jungle
     found the problem , the tail light and rear blinker wiring is situated under thr centre of the guard ,hit a decent pothole, cattle grid , etc the tyre has been making contact with the wiring and basicly fucked it !so we rewired it and shifed it to the side, hopefully solving the problem,thanks for the replies
