busted oil pan
  • jackschidt
    jackschidt
    g'day....put the kickstand spring through  the sump cover at 70kph...real freak accident..can't find a cast cover for a '96 dyna wide glide njywhere and looking at 3-4 weeks for one from the usa.    anybody out ther who can help?  thank....jack
  • DaveP
    DaveP
    how big is the hole?
  • jackschidt
    jackschidt
    about 25mmx50mm, but because it's cast metal, everyone says it can't be welded, fused or anything else....it's basically f----d. what do you reckon?      jack
  • jackschidt
    jackschidt
     i have  had them welded before they are alloy, a good welder can fix it up , but could find a good s/hand 1, the drain plug offen needs too be repaired  have welded them up before so as this does not happen again
    the welder i use is in Syd but wont be back untill 12 -18 jan
  • jackschidt
    jackschidt
    thanks for the help, boys....found an engineering shop open today and the guy said come back tomorrow and pick it up..seems cast can be welded with a tig..bit smartet than i was yesterday......jack
