fatbob question
  • chriso
    chriso
    Hi all, Im buying a second hand fatbob sometime in the next 6 mths hopefully and am hoping someone can tell me if there are any differences or changes from 07 to current models with the exception of the 103 cube this year. Cheers
  • BURTO
    BURTO
     Except for colour choices and a slight change in break rotor design, I don't believe so.
    Burto.
  • FatRob
    FatRob
     The new (2012) ones have ABS on the brakes and, I believe, smaller sensors on the exhausts.
  • chriso
    chriso
    cheers for the info,sounds like nothing drastic
  • Hesh
    Hesh
    I thought the latest model (could be wrong) had some funky dealer activated throttle control that turned off one cylinder when you rotated the throttle in the opposite direction. It apparently cut down on engine heat when stopped in traffic.
    Hesh
