Going down a cog
  • Robbo_Townsville
    Robbo_Townsville
    Anyone out there gone down a tooth on the front sprocket?
    Looking at it in conjunction with cams and headwork to get my 2009 FXST more grunt. Thought it might be a good alternative rather than increasing displacement.
    Robbo
  • DynaRider
    DynaRider
    30 t front is pretty common.
    It certainly helps takeoff.
    Higher rpm on the highway of course, but many complain 6th is hardly useable under 120 k anyhow.
    Speedo reading will be wrong unless corrected.
  • russ4570
    russ4570
    Is there a formula to work out engine RPM v Speed for cog reduction? What RPM increase will you get at 100 by going down 1 tooth?
    Regards Russ
  • Robbo_Townsville
    Robbo_Townsville
    Thanks Dyna Rider.
  • DynaRider
    DynaRider
    stock belt
