Larger tank for 883 " 94 " Sporster
  • stews
    stews
    Does anyone know what the largest capacity tank you can put on a 94 model 883 sporster, with out to much stuffing around?
  • evileye
    evileye
    I think the 4.5gal Nightster tank will be the biggest that'll drop in without too much fuss.
  • kingchops
    kingchops
     On a '94 the biggest factory tank would be a 3.3gal tank.  There are bigger after market tanks available.  Nightster tanks are 3.3gal but are all FI so they wont suit.  And the bigger Sportster C tanks will not fit as they are 2004+.
    I sell New after market King Sportster Tanks 3.4 Gal, bolt straight on $250.00
  • Fire511
    Fire511
    Walka, please tell me more, do you have something peanut styled and about 3.3gal to fit a 2011 48 EFI.
    No only Pre 07 Bikes
  • stews
    stews
    Thanks heaps mate, its for a g/f of mine, so could u tell me if there painted or unpainted? Or would it be easier to send me a pic to ujackdiving@hotmail.com or f/b Grant Stewart, thanks again appreciate ur post.
  • 883n Harley Convert
    883n Harley Convert
    that's the best thing about the model you have; there's a shit load of aftermarket tanks for carby bikes. If you wanna get creative, you'd be able to stick just about anything on there with a little modification
    We do them for 1982 to 1994 and 1995 to 2003
  • Womble
    Womble
    I have a 94 sporty myself and i,ve just put a 4.2 gal tank with the speedo and ignition on a tank dash
    fits well just have to finish putting everything together to see how far i get.
  • christopher
    christopher
    I have the king sportster tank on my 97 sportster sport its fine you should have no trouble with it
