Cal file not loading in TTS
  • paulsails01
    paulsails01
    Hi Guys.
    Over the last couple of days I have been experincing difficulty loading a reworked MT8 file for ECM programing download. Has anybody had this issue before?
    In the screen snapshot you can see at the bottom of the big window, (E:\...CAE176-03-AD-006.MT8) when I access the "Program ECM" command from the "File" dropdown menu, the smaller "ECM Programming Control" window appears as it should, but in the "File Information" box CAL ID, is the MT8 file CAE17603-00.
    The E:\...CAE176-03-AD-006.MT8 cal file is a saved file selected from the "Big V Twin" folder, opened to load load into ECM via the "Program ECM" command, MS OS is XP and I have full Administrator permissions.
    The CAE176-03-AD-006.MT8 cal file is a reworked CAE176-03-AD.MT8 file from the original TTS website download. The rework entails the usual "ECM Tuning Constants" ie IVO & IVC inputs and RPM limiter to 6000.
    What do I need to do to ensure that the selected CAL file actually loads up into the CAL ID box?
  • paulsails01
    paulsails01
    Hilly,
    You bloody beauty!
    It worked, I was under the assumption that when the file ID auto scrolled into the next sequential number that this was across the board.
    Cheers again mate, Paul.
