TC Soft tail oil line removal
  • KiwiRob
    KiwiRob
    Hi guys, need to know how I can disconnect the oil lines from the ol tank & engine or do I need the HD tool for the job.
  • AJ56
    AJ56
    Kiwi, you don't really need the tool. Just pull the covers away from the tank and remove the lines. Be aware that part of the system will stay inside the tank so when you go to put them back in sometimes the O rings come off and ddrop into the tank. Never happened to me. But if you are worries drop into a auto AC store they have the same clip to remove the lines from the tank. As far as the bottom fittings go they are similar but larger tool required. I have had my lines off before without the tool so it is doable. Just gotta be a bit careful when putting them back
  • KiwiRob
    KiwiRob
    Thanks fellas, I thought there had to be a way to do it without the HD tool.
  • KiwiRob
    KiwiRob
    Was a bit lazy last night, should have done a bit more searching. Found the AC fittings tool that you speak of AJ on the Sears web site.
    Thanks again
  • KiwiRob
    KiwiRob
    Thanks Beer Bandito, looked @ ordering from Sears but costs + freight from US ended up nearly 5 times the price of tool set. Just checked with Supercheap on-line over here in NZ, & it looks like they have them in stock.
    Thanks again.
