Throttle cable Replacement
  • elmodog1
    elmodog1
    Hey Guys, blew a throttle cable on a 2005 Softail Deluxe and was wondering how hard they are to switch out, looks like the original is cable tied to the backbone under the tank, so im not sure how hard this is gonna be, or should i just give to harley to fix
  • elmodog1
    elmodog1
    Thanks B yep im ok on the tools, but i havent attempted much work on the beast as i dont want to damage things i could have left to the Pros. But its a nice day and the cupboards full of Bundy, so it might be a perfect excuse to just sit look ponder and drink
    Happy new Year Brothers, be safe and thanks to everyone for the advice during the year, really do appreciate it
  • the_mongrel
    the_mongrel
    What he said!
    If they are similar to the newer models you can take all the bolts that hold your tank on and lift it enough to get to what you need. Just watch the balance tube at the front.
    Mongrel
  • the_mongrel
    the_mongrel
    PS - I have the stock set off my Fatty - if they fit, you can have em!!
