Switch block Hex what are they???
  • Bugger
    Bugger
    I'v been trying to fit after market grips to my new 2012 fatbob,,, I'v tryed both Imperial and metric alen keys, nothing seems to fit,,, could it be that HD have there own sized Hex heads so you have to get the dealer to do it,,,,,,,,,,, for Fuck syacks
  • WozzA
    WozzA
    ya need TORX head... not HEX...    a T27 will fit...
  • HogBag
    HogBag
    6 point torx not the 5 point torx.
  • Bugger
    Bugger
    Ok thank guys ,,,got it Torx heads, will try repco or a tool shop.
    Thank for your help
  • calais
    calais
    I'd be definately suggesting a tool store.
    Harleys these days are covered in many different fasteners and socket types.
    There are;
    -Torx Fittings (T6 - T60 will cover pretty much any eventuality)
    -Torx-R Fittings (just like a torx except with slightly more rounded splines)
    -Spline Drive Heads (A 12 point socket set can sometimes be used on these- be bloody careful though!)
    -Hex Drive Heads
    and... a multitude of imperial fittings.
    I must stress this though..... Torx and spline driven bolt heads are neither imperial or metric. Trying to adapt otherwise unsuitable tools for the job will only result in damaging the bolt head.
    Buy the right tools first time round, and minimise the risk!
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    fuckin stupid really havin all the different shit but spose they gotta sell the tools as well as the parts lol
    why do they call them allen heads when in the bolt shops they call them sockethead cap screws ????
  • Flak88
    Flak88
    Do the chrome bolt kits still have all the different heads on bolts or just hex ones. I want to change to chrome but finding the sizes is a bitch.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    i use stainless sockeheads an polish em before i put em on that ways you dont get the rusty look when chromes damaged in future
  • PK2
    PK2
    Having owned many Jeeps over the years I've found torx heads are extremely common - must be a Yankee thing!
  • Flak88
    Flak88
    Thanks OLD SKOOL. Will give it a go on some I have already. Cheers
  • calais
    calais
    Yep, the assortment is a true pain in the ass. Just wait until you strip one of the little buggers. Thats enough to really make your day.
  • BURTO
    BURTO
    No Torx screws on the switch blocks of my 2012 Fatbob.............imperial Allen head!
    Burto.
  • Rocky2010
    Rocky2010
    My 2010 Fatboy has Torx screws on the switch blocks, as stated before just buy as set of them and your done as there are different sizes on the rest of the bike. Also get yourself some Metric and Imperial Allen Head sets as well.
    One problem with Yankee bikes they have lots of different stuff in the way of tools so you will have to kit yourself out with the appropriate gear or you will have to take it to the dealer and that is something I would never want to do as they are way toooooo expensive.
