Online: obisteve
Map for 103" with 204's?
1/3
  • nhb006
    nhb006
    Anyone here able to help me with a base map for a 2011 street bob (ECM p/n 32852-11) with 103" and 204 cams?
  • nhb006
    nhb006
    Sorry, forgot to mention, SEPST.
  • JD
    JD
    let me have alook
  • HogBag
    HogBag
    I'm a TTS dude as well but if I was looking for a map to suit SE 204 cams. I would see If there's any to suit SE 203 cams as there very close with open, closing and lift specs. Now failing the 203 the next closest would be the SE 255 cams. The best way is to get the 204 cam specs and try and match them as close as posable with what's in the SESPT map base. Then check Ando thread on using the Smart (dumb) tune to bring the air and fuel in line with your engine.
    Good Luck
  • nhb006
    nhb006
    The other issue I'm having I beleive is my software version. - Mine is p/n 32111-10 (Version 3.004.0004) which is the 2010 year model update. The new software is p/n 32111-12.
    I can tune & flash older bikes, but I can't download my current tune (dealer popped it in as a favor) from the VCI and open it, or flash my bike with any other tune.
    - My bike is a 8/11.
    Im not sure what base tunes are offered in the 32111-12 software?
  • HogBag
    HogBag
    Fuck that don't sound good. Did the tuner marry to the ECM ? Hopefully no and you can sell it and buy another tuner. Have you talked to the dealer who sold you this tuner ? They might be able to run another tune in the ECM or give you one at cost price.
  • nhb006
    nhb006
    The dealer updated my VCI for me and used my VCI to upload their tune, so the VCI must work.
    All I can think of is it must be software related?
    The screamin' eagle cat says 32111-12 is required for all 2012 calibrations. - Other thing is, I can't find my ECM P/N (32858-11) in any of my software...
    It beats me, Ive never seen this happen before.
  • Ratshog
    Ratshog
    Have just bought the latest software for the SERT as i have a 2012 FXDF with a garage debaffle (V & H are draggin the chain on their big radius release). Given it a stage 1 reflash and although no real noticable perf change there is a definate econemy improvement 350k before the light comes on. The can map number to suit the Street Bob is 358SCV002
  • HogBag
    HogBag
    The 2011 softails and dyna's have a new ECM. The TTS won't work with these models either. My guess is the dealer sold you the SESPT for the early dyna's that does not suit your ECM. What month/year is on your compliance plate. I'm thinking you have a 2012 built in 2011.
  • JD
    JD
    think you just need to get the extra cd for you model if the dealer used your vci
  • nhb006
    nhb006
    Thats what Im thinking JD... just waiting for my stealership to open up on the 3rd.
    Can anyone tell me if theres a tune for 2011 fxdb 1690 with 204's in the new software?
  • JD
    JD
    your ecm number comes up in the old one
  • nhb006
    nhb006
    The old software?
    Great... back to square one.
    Can I ask what tune file you seen the P/N in?
  • nhb006
    nhb006
    Just had a look through my version, I cant find any ECM P/N's ending in 11... ?
    hm.
  • lonewolf
    lonewolf
    Try 176ST002. You will have to bump the cu in to 103 in the tuning constants.
  • nhb006
    nhb006
    I'm not sure if that will work for a 103 with 204's because the VE tables remain the same as the 96, even when you up the cubes?
    I'll wait till the stealer opens & order the new software. - See if that solves my VCI issue, and I'll go from there. - I've PM'd Nev, see if maybe he could supply me with a base for the 103 & 204's.
  • JD
    JD
    Photobucket
  • JD
    JD
    thats the old one
  • nhb006
    nhb006
    Ok JD, now I'm really confused. - I cant even find that open menu where you can type what you are looking for anywhere in my software, and my file for 176AF106 says 32852-08A, nothing 10 upwards....
  • nhb006
    nhb006
