MIKUNI 40 MM jet sizes
  • Bourkie
    Bourkie
    Hi would anyone know how I would find the correct jet sizes for a MIKUNI 40 MM pumper with these markings (T Q Z 1) AND (V 40 W )  would this make a good carb for an 85 evo?
    Bourkie, I doubt there's such a thing as "correct jet size" for any Carby.
    Way to many variables depending on the engine setup with Exhaust and Air filter etc'.
    Mikuni have a very good tuning guide on there website to walk you through jetting.
    http://www.mikuni.com/fs-manuals.html
    Personally I use a digital logging wideband o2 meter for tuning.
    A 40mm Mik' should work well on an Evo, or a late 40mm CV would work also.
     hi,   if it's the 40 mm smooth bore flatslide carb  for the harley they are a good carb ,   it should have the cable wheel on 1 side ' with a short  idle cable  adj under the body ?          idle jet  17.5 m.m. idle air bleed 0.9 m.m., main jet about 1,75 -1.80 m.m.  you can play with the main tube & main air bleed but if you don't know how  don't  i have jet's & K&N air cleaners in stock for this model carb,
    people through them out for a 42 m.m. & i collect them as i like these carb's  & can get them working good   the slide can rattle @ idle if it's worn  but when on the throttle it will be good  as the gate is open & no suckion on the gate @ idle ,  no worries
      stock idle air bleed is 1.1 m.m.  & is  too lean  if yougo to a 2.0m.m. idle jet it;s too rich ,     i wish i was too - rich
  • Bourkie
    Bourkie
    Well there you go while I was thinking about buying the Mikuni carb someone else actually paid the $100 for it and I am still looking, so it might end up being a CV off a 96 fatboy if nothing else turns up
    thanks for the help guys
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    bucca actually lol an ya dick its old skool custom bike repairs and towing ..the towing starts 1/1/2012
    numbers are 0741578232 or 0450511192
  • issues2
    issues2
    I was close lol.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    i got shit load cables an mmmm some carbs an bits threw bout 2 garden sheds full bits out before i moved here lol still got heaps in boxes let me know if ya chaseing anything ya never know wats in my sheds turbos nitros mmm jappa drag bodies ummmmm heads monoshock rear sporty frame lol hope it works out for ya bourkie an remember i only down the road also do powdercoating as well
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    yup
