TTS mstrtune installation issue
  • paulsails01
    paulsails01
    Hi guys,
    I am hoping that someone may have some knowledge of my immediate TTS problem. I have commenced installing the programe onto my laptop but when the "updater application" has commenced and completed the first update download, I have recieved the error message
    "Datamaster-HD-setup-183-exe has failed the file verifiction. Expected checksum: "2ae616cb979601fc91668595d6b1bc". Computed checksum "c6cb022clc568bdf998cefee5feef80bff1".  This may indicate a corrupt file, pse try re-down loading."
    I have attempted the "re-down loading on several occasions with the result the same message flagged.
    Can anyone shed some light on this or offer advice on what steps I should take to erradicte this problem.
    regards,  Paul.
  • Steve Cole
    Steve Cole
    I would uninstall Datamaster if you got it to install. The make sure that you try installing from the disc with your antivirus turned off. Some of those will really screw around when installing software,. What version of windows are you trying to install on?
  • paulsails01
    paulsails01
    Hi Steve,
    Many thanks for a reply, I have installed this from a disc I purchased from "Robs Cycle Supply" onto a MS XP OS that I have installed onto a Toshiba Satelite L300 laptop. The only antivirus I have installed is what is supplied with this XP, I do not have a 3rd party type installed. I shall uninstall with this antivirus turned off, reinstall Datamaster then initiate the updater program and see how we go.
    Cheers Paul.
  • paulsails01
    paulsails01
    Steve,
    I have just completed the initial download with "updater program' as required to configure Datamaster for commencement of proceedings. Many thanks for your input, I am sure that as I get into it there will be other help queries that you and other members will be able to assist.
    Once again many thanks, Paul.
