Blackline tank panel on normal softail tank?
  • Slippery1
    Slippery1
    Hi,
    I have a 06 nightrain and want to know if the Blackline tank panel will fit on the standard softail tank to replace all the speedo and ignition etc.
    I will have mirrors that incorporate digital speedo,RPM,km's etc.. and want a lower look on the tank.
    I called the local HD dealer spare parts but they did not know or really care to find out.
    Any thoughts?
  • Isaac
    Isaac
    Tricky one there Slippery... perhaps because the Blacklines are brand spankers no-ones tried this before.
  • Gnoo
    Gnoo
    Yeah, I think ya off ya head           no disrespect intended
    A custom leather inlay/overlay would look sweet  and low
  • Slippery1
    Slippery1
    Basicly with the look im going for is stretched low profile tidy look, im most of the way there but I want to put drag bars on the 1.5" risers. If I do this the current softail dash will be the highest point on the bike so i want to smooth the top of the tank (basically the look of the Blackline tank).
    I know what i want it to look like in my head and I know it will look shit hot as well. There will be no visible guages sticking out
  • softyJ
    softyJ
    Would be worth looking at the mounting points of both tanks to see if it will fit your softail. Then looking at how the wiring/switch is relocated, Good luck with the swap. Don't forget to get a pic up when it's done
  • Trek52
    Trek52
    where are you mate? If in Syd come an have a look at my blackline and see if it will work
