blinkers on 85 evo?????????
  • Bourkie
    Bourkie
    On my 85 FLHTC the indicators only work while you hold down the switch on either control is this normal?? or should they stay on and self cancel
  • Bourkie
    Bourkie
    thanks Dave, I’m heading for the rego inspection on Monday if it isn’t raining so will just tell the guy that all 85 Harley blinkers have to be held on to work and hope he believes me and hasn’t read this forum
  • The Don
    The Don
    Hi Bourkie,
    From 82 to I believe 90- 91 the switches had either a hold in to blink (USA models) or a rocker type flick on and flick off (Aust models, and by what Dave said UK models as well) I have seen bikes using the hold in USA switches here. From 92 on they used self cancelling switches. One of these situations where you hold your ground and say convincingly " That's Factory stock set-up."
    Cheers,
    Cris.
  • Bourkie
    Bourkie
    thanks Cris I will
  • motor_head
    motor_head
    Yep alls good Bourkie, the switch has to be held on to work, release the switch and they stop, in america it was/is illegal for the indicators to stay on and thats the best they could do in them day's (pre computer) .... well thats what i was told by someone who should know.
  • The Don
    The Don
    These were the supposed right ones, says to 88 but my 89 Heritage has them.
    Harley Indicator switches ( flick on- flick off)
    Fits: 1982 - 1988 Models - International
    Part Numbers: 71581-82 + 71579-82
  • Burnzi
    Burnzi
    Yep hold em on while you want them on, let go and they are off. Pain in the bum if ya got stumpy fat fingers like mine. I fitted a Badlands Pro 111, this switches them on for 11 seconds and allows you to run LEDs as well.
  • Bourkie
    Bourkie
    Have just ordered a Badlands pro 111 from East coast custom should be here tomorow thanks Burnzi
  • Bourkie
    Bourkie
    just fitted the Badlands ATS 03 very ezy to solder in and they work a treat
    Thanks guys and have a top X-mas
  • FXRfreak
    FXRfreak
    Well if you guys have '86 bikes with indicators that need to be held on, they must have had 2 different types in '86, because my FXR is an '86 still with original factory switches on it, and after switching on they stay on till they are manually switched off. I think your way is better in some ways though, because I have occasionally forgotten to turn them off, which is very dangerous.
  • Paddy
    Paddy
    my 88 heritage came from a dealer in gainsville georgia usa with the hold on blinks got used to em quick had to.
  • OL SKOOL CUSTOMS
    OL SKOOL CUSTOMS
    got self cancellin setup in shed mmmm oh well never seen this till to late
  • Bourkie
    Bourkie
    yep Buca is a lot closer to Gin Gin than the post from down Syd way I will keep you in mind when I am looking for gear in future
    Cheers,
    Peter
