Online: Retroman, GGUser744
ABS removal
  • oneball
    oneball
    Hi all...Im seriously considering removing the ABS system on my 2011 fatboy low.I want to fit the Shotgun air suspension under it,But to do so i have to remove the ABS.
    Has anyone done this?Did they run into any problems? or is there anything anyone can shed some light on the subject.
    PS,Im not interested in hearing  about ABS vs Non ABS.
  • JD
    JD
    you cant by pass the ecm to make it think it hasnt got ABS it will make your life hell
    but hey have a go
  • oneball
    oneball
    Hi all...Thanks for the replies.The ABS light flashing would drive me nuts,Thats for sure.I have even thought about breaking the little ABS light bulb,LOL.I dont want to be a the first to do it either,And learn the hard way and run into all sorts of problems.
    Ando...Can the Progessives be wound up harder than the stock shocks for 2up?I occasionally put the missus on the back of my FatboyLow,And it bottoms out way to much on good roads.Thats the only reason i want to fit the Shotguns.
